01-13-2006 02:37 PM
01-15-2006 10:07 PM - edited 01-15-2006 10:07 PM
Message Edited by JoshuaP on 01-15-2006 10:08 PM
01-16-2006 09:01 AM
01-17-2006 09:46 AM
01-17-2006 11:38 AM
01-17-2006 11:40 AM
01-20-2006 10:13 AM
The hardware was working all along even though the software did not seem to be installing correctly. I found this out by ignoring the error message, wiring the hardware for loopback testing, then running hyperterminal.
I did as Joshua described but that did not change anything. I talked to NI tech support and they had me run NI Blast to uninstall all registery entries thinking that part of it was corrupt. (One weird thing I noticed while unistalling NI stuff was that in the Add/Remove Programs list just below NI software was a huge blank entry that took up a cupple hundered rows of text space. The blank entry went away after uninstall all NI stuff). I then installed just NI Serial then the hardware. Still got the errors.
In then end I just left the error message window up and started using the hardware. For unknown reason(s) the error message no longer appears. This happened after reboots for other reasons. The only difference in one of the reboots was that I had the LAN network connection disabled because I had just finished using dialup to play a little Wulfram(Look it up if you like. :{} ) and I disable the LAN during that time. There is normally an unexplained delay of 1 minute after I type in my user name and password and hit the login button to the time that the PC "wakes up" and shows the desktop but with the LAN disabled there was no delay(under Control Panel, Network Connections). This is when the error would begin to appear also. I'm sure Josua "The Brain" P can explain this. 🙂 Thanks for the efforts of all repliers!!!
