取消
显示结果
搜索替代
您的意思是:
NI Max ver15.5 is not working with Win 10(It only able to connect a few hours)
Ni MAX is able to detect and working USB-GPIB HS with a few hours before disconnect.
After disconnected, I need to Close all Labview 2013 then re-scan the GPIB in the NI Max only then it work again. But after few hours it will disconnect again.
Hardware: USB-GPIB HS
OS: Win 10
Labview 2013
Test with NI Visa -
1. Ni MAX (NI Visa) -15.5
2. Ni MAX (NI Visa) -17
3. Ni MAX (NI Visa) -18.7
All NI Visa above is not working
0 项奖励
1 条消息(共 3 条)
2,740 次查看
This has everythin to do with power savings on the USB bus devices.
Check your power settings and forbid windows to save power when not on batteries.
greetings from the Netherlands
0 项奖励
2 条消息(共 3 条)
2,721 次查看
While not specifically for USB-GPIB-HS, here's how to fix your problem..
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7POSA0&l=en-CA
Here's some other tips I posted awhile back for the USB-GPIB-HS issue.
https://forums.ni.com/t5/LabVIEW/Re-Intermittent-VISA-errors-10073807194-connection-for-given/m-p/38...
And some more hints that might be relevant..
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/VISA-Limitations-Number-of-Instruments-Type-...
Craig
0 项奖励
3 条消息(共 3 条)
2,706 次查看
