NI-9871 - which transmit mode for multi-drop RS485 communication?
Ports of the NI-9871 have 4 transmit modes: 4-Wire, 2-Wire DTR with Echo, 2-Wire DTR w/o Echo, 2-Wire Auto.
Which of these modes are suitable for multidrop communication, what advantages or disadvantages each of them has?
Seems 4-Wire is poor: needs more wires, and devices that the NI-9871 port "talks" with all use the same line for sending data to the port, and possibly they are even unable to detect a conflict if many of them transmit simultaneously.
If a program is to turn transmitter on and off, it must know when the action can be done safely - I suppose turning off the transmitter while it sends a data will result in sending a distorted data. And I don't see any signal from the port that can tell whether the transmitter is busy or idle. Is there such a signal that I overlooked?
Some devices need some "idle" time before or after sending anything to them - their behavior is unpredictable if it is violated. I want the program to enforce sufficient "idle" times, but how can it know the RS485 line is idle?
(296 Views)
Not sure what you are trying to tell here or ask.
Do you want to communicate with existing devices, Set-up something new, or ???
Kees
(189 Views)
Generally, these are existing devices; maybe some that I don't know, but I will not create any.
Here are results of my tests of NI-9871 C-module port. I used a 3-wire cable (D+, D-, GND) for communication; connections of the DE-9 Male Connector pins: p1=GND, p2=p3 (CTS+,RTS+), p4=p8=D+ (RXD+,TXD+), p5=p9=D- (RXD-,TXD-), p6=p7 (CTS-,RTS-); I tested all modes (including 4-Wire in spite I didn't have 4 wires).
In some modes connecting CTS to RTS aids verification of connections - it is the only way that I know for detecting a lack of power supply, or a disconnected signal cable (e.g. on the DE-9 connector).
Abbreviations: N/S/H mean Flow Control (FC) is None / Software (XON/XOFF) / Hardware (RTS / CTS); 4W/2E/2D/2A mean Transceiver Mode (TM) is 4-Wire / 2 Wire DTR Controlled with Echo / 2 Wire DTR Controlled / 2 Wire Auto; a 5-char symbol specifies DTR State / RTS State / CTS State (each of them is
u = Unasserted or A = Asserted) followed by -|T|R|B and -|E (T = Transmit to line, R = receive from line, B = Both, E = Echo).
The test results are:
N4W: uuuTE, uAATE, AuuTE, AAATE; CTS=RTS, TE
N2E: uuuR-, uAuR-, AuuTE, AAATE; CTS=DTR&RTS, DTR?TE:R
N2D: uuuR-, uAuR-, AuAT-, AAAT-; CTS=DTR, DTR?T:R
N2A: uuAB-, uAAB-, AuAB-, AAAB-; CTS=A, RT
S4W: uuuTE, uAATE, AuuTE, AAATE; CTS=RTS, TE
S2E: uuuR-, uAuR-, AuuTE, AAATE; CTS=DTR&RTS, DTR?TE:R
S2D: uuuR-, uAuR-, AuAT-, AAAT-; CTS=DTR, DTR?T:R
S2A: uuAB-, uAAB-, AuAB-, AAAB-; CTS=A, RT
H4W: uuuTE, uAuTE, AuuTE, AAuTE; CTS=u, TE
H2E: uuuR-, uAuR-, AuuTE, AAuTE; CTS=u, DTR?TE:R
H2D: uuuR-, uAuR-, AuAT-, AAAT-; CTS=DTR, DTR?T:R
H2A: no such a mode, the previous is kept!
(? as in C: DTR?TE:R means TE when DTR=A, R otherwise)
When the signal cable is disconnected, the CTS is u for *4W and *2E modes, DTR for *2D, A for *2A modes. Note: seems some signal changes are delayed!
H2E, H2D modes: if write is done while DTR=u, the data is sent when DTR becomes A (with echo received for H2E); this doesn't keep for their N/S counterparts!
The problem is that NI's documentation doesn't state clearly how do 9871's ports behave: I cannot predict results of using at least some of their modes basing on their documents; I can test a port behavior, but this gives me only knowledge on the behavior tested, not on the behavior the next 9871 - they may change an undocumented concept and in future make 9871-s with ports behaving differently, and a system using a 9871 may stop to work after replacing the original 9871 with a new one.
Attached are programs used for my tests, versions for LabVIEW 2018 and (in the ZIP) for 2010.
For both: Baud Rate, Data Bits, Stop Bits and Parity can be set before running only; Transceiver Mode, Flow Control and Break State can be changed while running; I didn't notice any effect of Break State value; Baud Rate Prescaler and Divider are shown.
ni9871fpga-mt.vi tests "modem signals" in a selected mode for all 4 DSR and RTS combinations and shows CTS after 500µs (note the CTS comes from the port connector and its changes are delayed); I noticed some bug in LabVIEW (2018): when the '4' (i32) and 'F' (bool) constant were outside the While loop, LabVIEW assumed it creates variable-size arrays; the '4' inside While is OK.
ni9871fpga-mt.vi sets DSR and RTS from UI, show CTS, has counters for CTS, CTS == RTS values, and for received data, and sends data (0x58 = 'X') on button pressing; on a PC I have a program (ttyusb0.zip, in Tcl for Linux, for Windows need change the port name which for Linux is /dev/ttyUSB0) that receives and sends data bytes (received data is shown as 2-digit hex value, sending is shown by dot), this setup allows me to test when the NI-9871 sends and receives data, and when it gets echo of the data sent.
I still don't know what the NI-9871 port does if another device on the line is active when it is to send: delays or sends causing a conflict? Using Echo mode allows detection when the data was really sent.
(176 Views)
Maybe there devices (transceiver IC's) that can see if the line is idle, but I never saw them.
The applications I know is a single master and multiple slaves.
I think what want (multiple masters) will need a single main master that controls the traffic.
In case of the ModBus protocol I would use a ModBus gateway.
What protocol does your application use?
(151 Views)
Unfortunately, I have several different devices using different protocols. And I cannot have enough RS485 ports to be able to use only one protocol on each port. Therefore, one of challenges is to find sets of not-conflicting protocols (I don't want a communication with one device to be recognized by another device as a command, like reading a  pressure or temperature resulting in byte sequence causing a valve to open or close...).
(129 Views)
Without knowing what protocols you use, I think it will be very difficult to solve it with a multidrop.
You can have 255 COM ports (Windows) on your computer.
With additional devices maybe even more.
Will easier than using a multidrop line.
(122 Views)
I am asking about general guidelines for NI-9871 usage, not for using it with a specific protocol. And I doubt you would like to read all protocol details for these devices that I am to control.
Manufacturers of many devices provide LabVIEW drivers for them, but they can be used when a port has connected one device, or one kind of devices, and I have many different devices, therefore these drivers are useless for me.
And I cannot use Windows for controlling these devices. A PC that runs Windows has no slot for NI-9871. The program that is to control these devices is required to run in FPGA, not on a PC. I must act within these limitations.
(97 Views)
