Multiple serial read overrun error.
Hello All,
I am scanning two serial ports (barcode scanners on usb ports with usb to serial converter) simultaneously and creating an array for the different entries as shown in VI
Apart from it I am also scanning Digital inputs (not shown in attached VI, in a while loop).
Sometimes, I get an overrun error, how can I overcome it or what changes should I made in my VI.
I am using LV 2013
Thanks & Regards
JP
(3,384 Views)
What is the data being scanned?  I am more concerned with the format.  Typically, bar codes will used ASCII representations for the letters and numbers and then end the data with a Line Feed character.  If this is the case, then you need to enable the termination character.  Regardless, you really should not be using the Bytes At Port to tell the VISA Read how many characters to read.  There are much better ways, but they depend on the data format.
(3,370 Views)
Barcodes in ASCII will be scanned, around 12 characters.
(3,367 Views)
And they end with a Carriage Return and/or Line Feed?
(3,358 Views)
Hi Cross
No they dont end with line feed, or carriage return
(3,339 Views)
Well, regardless, with a barcode, they should always be the same length.  So just tell VISA Read to read the 12 bytes.
(3,333 Views)
