Missing NationalInstruments.DAQmx.DLL
I'm using VB .NET with Visual Studio 2010.
I've downloadad the lastest version of NI-DAQmx, but when I call the NationalInstruments.DAQmx.DLL library the program says that component can't be found.
Where can I find this library?
Thanks.
(14,347 Views)
When you installed DAQmx, did you include Support for Visual Studio?
-AK2SM
(14,340 Views)
I don't know, how can I see it?
(14,321 Views)
Accepted by J_Kidd
I've never installed those support  features, but if you already installed DAQmx, you should be able to install the required additional components needed similar to what is shown here:
http://digital.ni.com/public.nsf/allkb/52F5F5EF78AF084286256E0B007FE793
-AK2DM
(14,317 Views)
When I update my Ni-DAQmx to the .NET Framework 4.0 I suppose I won't have problems with the libraries or I have to move the libraries to a specific place or call it from my program Visual Studio?
Thank you.
(14,312 Views)
Sorry, I do not have an answer for that since I have never used VS. Hopefully someone else can provide an answer.
-AK2DM
(14,300 Views)
You probably just need to add a reference to the DAQmx library
Goto menu 'Project' and click 'Add Reference'
Curt
(14,293 Views)
