MacBook Pro with Thunderbolt 3 ports
Hi. I want to buy the newest Macbook Pro, which has only Thunderbolt 3 ports, and no USB ports. I want to know if I'll be able to connect to NI hardware (DAQs, USB-to-GPIB-HS) with a Thunderbolt 3 to USB adapter.
(3,139 Views)
Accepted by topic author RH7
Hello RH7,
Yes you will be able to connect to those USB hardware without issue. Thunderbolt 3 is an "all in one" port that can run USB, Thunderbolt, and DisplayPort. That means no special Thunderbolt 3 to USB adapter needed (these don't exist anyway). Just use a basic USB-C to USB adapter and plug them in directly.
As a side note, NI has recently released PXIe-8301 (https://www.ni.com/en-us/shop/model/pxie-8301.html) which will allow your Macbook Pro to connect to a PXIe chassis via Thunderbolt. If you run Windows OS on your Mac, you can take full advantage of PXI/PXIe hardware.
(3,127 Views)
