キャンセル
次の結果を表示
次の代わりに検索
もしかして:
MAX API
I would like to know if there is an API for Measurement and Automation eXplorer?
It woud be to configure IVI instrument drivers under MAX with a CVI application.
Regards, Pascal.
0 件の賞賛
メッセージ1/3
3,856件の閲覧回数
IVI Engine 2.0 has function which returns handle to Config Store. This function you can find in IVI Library>>Configuration>>GetConfigStoreHandle. This handle you can use for function from IviConfigServer.h.
I attached test.c file which reads all logical names from your config store. More information, you can find in IviConfigStore specification on www.ivifoundation.org.
Zdenek
0 件の賞賛
メッセージ2/3
3,856件の閲覧回数
Hello Pascal,
The IVI Foundation has defined a C API to programmatically access and modify any IVI Configuration Store file. This API is defined in the IVI-3.5 IVI Configuration Server specification and is installed as part of the NI IVI Compliance Package 2.x. The relevant files are installed in the C:\Program Files\IVI\ directories. These are IviConfigurationServer.h, IviConfigurationServer.lib, and IviConfigurationServerCAPI.dll.
Atteched is a simple example on how to programmatically access the configuration file.
I hope this helps!
Vesna Jadric
Instrument Driver/IVI
メッセージ3/3
3,856件の閲覧回数
