06-03-2015 11:05 AM
I wrote a Labview program on a PC wiht an inernal GPIB Controller card to control a GPIB Electronic Load using NI VISA and vendor supplied Labview VIs that use NI VISA. I now have to implement the same program on a laptop using a LAN to GPIB Converter from NI to talk to the Electronic Load.
What is the difference in how this LAN to GPIB device gets programmed verses a direct gpib controller for the same instrument? Is the code that I have written already not usable? Do I have to write direct TCP/IP Commands now out of my Labview program?
Solved! Go to Solution.
06-04-2015 04:40 PM
Hi there,
The only difference between using a standard GPIB port and the ENET-GPIB is how you set it up and configure it within MAX. From there, it will behave exactly the same. All of the TCP/IP routing is done automatically.
06-05-2015 09:01 AM
So I can use the VISA Library for the instrument in labview and it will work for both GPIB or this Ethernet. I just have to redefine the interface to switch between the two?
Sounds great.
06-05-2015 10:04 AM
06-12-2015 04:26 AM
I am also facing similar problem, Can you suggest the address / visa resource name used?
06-12-2015 05:12 AM
06-15-2015 06:36 AM
I have written a LABVIEW progam to control a device using GPIB interface.Now I ned to modify it for using it though a GPIB- ENET 100 device. How should I do that? What Address format to use in Visa Rsource?
06-15-2015 09:37 AM
