09-10-2009 04:44 AM
Good Day Everyone;
i am new to Labview and recently i have just started experimenting with Labview but i have met up with some problems, i was wondering if anyone here could provide me with their technicak expertise advice. I am basically trying to control the signals sent out by Tektronixs Arbitary Waveform Generator AWG2041. I am controlling the signals via GPIB cable, PCI-GPIB. However it seems that after installing Tektronix's AWG2041 Driver and installing NI-VISA, i am still experiencing some problems, i have this error upon compiling. I have used the MAX tool to scan for the insturment and it has successfully found and communicate with the insturment when i use the communicate tool.
Error -1073807195 occurred at Old VISA Open in TKAWG2041 Initialize.vi->awgrun.vi
Possible reason(s):
VISA: (Hex 0xBFFF00A5) The interface type is valid, but the specified interface number is not configured.
Prior to that i had another error 1073807343 which it was due to the error of not installing the NI-VISA. May anyone help me out here. Thank you very much.
09-10-2009 06:33 AM
09-10-2009 10:08 PM
Hi;
thanks for the advice. I am able to initalize the AWG2041 upon amendment to the Visa open. However, i still encounter the same error code when running my program itself. It shows the same error code. Would you be able to provide me with your advice again. I have attached my progam along here including a screen shot of the front panel. Thank you.
09-11-2009 12:52 AM
09-11-2009 08:57 AM
