I thought it was easier to use the IVI driver as the manufacturer had created to facilitate the task. The idea was to use the examples of the other models changing Close and Initialize VI, but for that I need to have these VI in tools palette.
It's weird because i just installed the IVI driver for tktds7x4 (or downloaded from website) and works fine. But doing the same process With The IVI driver downloaded from Rigol site it does not work. What do you think is the problem?
I have installed the compliance package and I can see the functions.
Sorry, I read with interest all your posts for real. But I do not know how to do the dll import. If possible I would like you to tell me how?
Ok I ran the msi file. This results in Program Files (x86) \ IVI Foundation \ IVI \ Drivers two files (a file .fp and other one .sub) in a directory.
When I acces to Tools> Import > Shared Library (.dll) I need to find a dll file and another .h as you said above. Where I can find these dll and .h files?
