LIN To USB Bus Monitor
Hello, I have a NI USB TO LIN converter that has to DB-9 ports.  I open up NI Max and run the Bus Monitor on one of the ports to read the LIN packets being transmitted on the the first port.  I have the 2 ports connected so that this works.  However, I only am recieving the response messages from the LIN devices and not the actual commands to the LIN devices.  I looked all over the bus monitor in NI Max to try to find the setting I am looking for and was not able to find anything.  Does anyone know how to configure Bus Monitor to see both the messages to my devices and the responses from the devices?
(1,385 Views)
Accepted by topic author Fifty60
It ended up being a Baud rate issue
(1,341 Views)
