11-03-2008 07:06 AM
Are there any plans to update the LDF toolkit for LIN 2.1 ?
The Node attributes of LIN LDF files have changed significantly with a result that the LDF Open Database.vi now returns an error on attempting to open a 2.1 file.
Mike
11-12-2008
03:18 AM
- last edited on
03-01-2024
08:51 AM
by
migration-bot
Hi Mike,
I am assuming you are referencing the LDF Kit: LDF Starter Kit for LIN Version 1.0 for Windows 2000/XP. If so, there currently is not a plan to update it for LIN 2.1. Please provide feedback at www.ni.com/contact on what specific features you are interested in.
Kind Regards,
12-02-2008 11:07 PM - edited 12-02-2008 11:10 PM
So that is to say, it is not possible to read LDF in LIN 2.1 under LV? Is there any other solution?
Thank you!
12-03-2008 02:55 AM
You can still read v2.1 LDF files under Labview if you remove the configurable frames elements in the Node Attributes section.
This sorted out my problem.
Hope this helps with your application.
Mike
