LDF Toolkit for LIN 2.1
Are there any plans to  update the LDF toolkit for LIN 2.1 ?
The Node attributes of LIN LDF files have changed significantly with a result that the LDF Open Database.vi now returns an error on attempting to open a 2.1 file.
Mike
(5,587 Views)
Hi Mike,
I am assuming you are referencing the LDF Kit: LDF Starter Kit for LIN Version 1.0 for Windows 2000/XP. If so, there currently is not a plan to update it for LIN 2.1. Please provide feedback at www.ni.com/contact on what specific features you are interested in.
Kind Regards,
Daniel T
Account Manager
National Instruments UK & Ireland
(5,537 Views)
So that is to say, it is not possible to read LDF in LIN 2.1 under LV? Is there any other solution?
Thank you!
帖子被jie.wu@micron-china.com在 12-02-2008 11:10 PM
时编辑过了
(5,444 Views)
You can still read v2.1 LDF files under Labview if you remove the configurable frames elements in the Node Attributes section.
This sorted out my problem.
Hope this helps with your application.
Mike
(5,437 Views)
