Keithley 6517b Remote Humidity Measurement
I am using a 6517b to measure currents and apply voltage to a device under test.  Along with the current reading I would like to log the humidity using the optional humidity probe.  How can this be done?  I am using Labview 2016 and operating the device over GPIB.
Thanks!
(3,015 Views)
I don't have one to test this on but did demo a unit and use some of the Keithley software to record Temp/%RH with the data we logged, so it can be done.
You can find the LabVIEW driver here - http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=2C23A2069DC43544E05490E2BA35FC...
The driver contains VIs to enable Temperature and Humidity Monitoring.  Once enabled your buffer reading will have those values of temp & %RH appended.  See the example with the driver "Keithley 6517 Trace Buffer Store and Read.vi" for reading the buffer.
Good luck.
(2,990 Views)
