Keithley 2100 and Labview 7.1 ?
I am the (happy ?) owner of a new Keithley 2100 and all the drivers I found are for Labview 8.0 or later. I want to use this device on a WInXP machine running Labview 7.1 (On another machine I have a LV8.5 but I can not save this Keithley VIs to earlier than 8.0 version). Any advice on how to do this (down) conversion ? Is it possible ?
Thanks for help,
N
Message 1 of 17
(8,500 Views)
It's possible for someone with LabVIEW 8.0 to save as 7.1. You can attach the 8.x driver and ask for someone to do the conversion. I don't have 8.0 so someone else will have to do it.
Message 2 of 17
(8,497 Views)
Hi
thanks for the message. Here is the instrument driver in LV8.
Is there any kind soul owner of a LV8 to make this conversion ?
Thanks and regards,
N
Message 3 of 17
(8,489 Views)
Message 4 of 17
(8,469 Views)
Accepted by nitad54448
I experienced some troubles with LabVIEW 7.1 and I need to reinstall it, but here are the saved for previous version VIs....
Message 5 of 17
(8,464 Views)
I too have just taken posession of a shiny new 2100. Thanks to everyone for posting 7.1 drivers.
I would give you all stars but I don't have enough posts to do so yetSmiley Mad
"...and all this science I don't understand
it's just my job five days a week"
Using 6i, 7.0 & 7.1 on Win'98, 2K & XP
Message 6 of 17
(8,453 Views)
Place the converted files in instr.lib directory; it's not a marvelous solution, but you will be able to use the driver with LabVIEw 7.1. Sorry, but I don't have the time to prepare a complete driver and to rebuilt the palette system; if someone could take the time to do this, in comparaison with what is present under LabVIEW 8.0 (see below), don't forget to submit your job there and on the driver network.
Thanks in advance!
Message Edité par Mathieu R. le 11-23-2007 02:34 PM
Message 7 of 17
(8,445 Views)
hi
they seem to work... thanks a lot
regards
N
Message 8 of 17
(8,441 Views)
hi
regards
N
Message 9 of 17
(8,440 Views)
Is it possible to convert to v6.1?
Message 10 of 17
(6,855 Views)
