01-29-2018 05:52 AM
Hi all,
I've inherited a script to log resistance measurements from a Keithley 2000 multimeter and have been trying to set it up on a new computer. I've tried both drivers I was able to find online (http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E960B659CE034080020E748... and http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=248) and tried it in Labview 2017 and 2016.
I'm new to Labview (and coding in general) and have found the online training courses but would like, if possible, a quick fix to start taking measurements again. Is anyone able to get it to run?
Many thanks in advance!
01-29-2018 11:07 AM
Pretty hard to help when you don't describe a problem.
Describe what's not working, and what you expect. Describe the error message you get, error logs, and any other pertinent info that might be helpful.
01-29-2018 12:16 PM
Looks like it was made with this 2004 LabVIEW driver which you can't download from those links. You could update or use the older version attached.
