Instuments command
Hello, I am trying to send multiple commands to an instrument GPIB and USB via instrument driver in Labview, connected to the write buffer, I am using the concatenating block, is this correct in your opinion?
(1,373 Views)
Accepted by topic author Slash96
That depends on the instrument you are communicating with.  Some instruments have no issue with combining commands into a single message.  Following the SCPI standard, the commands are separated by a semicolon (;).  Other instruments, however, have a very limited command buffer and you have to give time for the instruments to process the commands before sending the next one.
(1,363 Views)
