11-10-2022 04:34 AM
Hello, I am trying to send multiple commands to an instrument GPIB and USB via instrument driver in Labview, connected to the write buffer, I am using the concatenating block, is this correct in your opinion?
Solved! Go to Solution.
11-10-2022 05:50 AM
That depends on the instrument you are communicating with. Some instruments have no issue with combining commands into a single message. Following the SCPI standard, the commands are separated by a semicolon (;). Other instruments, however, have a very limited command buffer and you have to give time for the instruments to process the commands before sending the next one.
