Instruments not found
I've GPIB-USB-B, DMM HP 34401A and Tektronix TDS754C.
I've connected GPIB with DMM HP 34401A,then to scan instrument and did not find the problem.
After that, I've connect the GPIB with Tektronix TDS754C and scan instrument but the software show that instrument not found.
...Please help...
(3,507 Views)
Anybody, please let me the information for fix this problem?
(3,483 Views)
Hi hork,
Both the 34401A and the TDS 754C are very common instruments, and are widely used with our GPIB products. I am glad that the DMM works with the GPIB-USB-B, because that indicates that the GPIB-USB-B is working properly. Have you checked all the settings on the 754C to ensure they are set properly? Also, do you have another GPIB interface that you could use to try to detect the 754C? It could be a simple issue of a malfunctioning instruments.
john
Applications Engineer
(3,460 Views)
Hi John,
Thank you for your reply.
I don't know how to setting the TDS 754C for communicate with GPIB.
I've a PCI-GPIB and could not detect the TDS 754C same as the GPIB-USB B.
However, I will research the 754c setting method in the internet.
By the way, If you have a setting method please let me because it's can save my development times.
Thank you so much for your help.
Surin
(3,448 Views)
Hi John,
I've setting the TDS 754c and it's work well, MAX can scan and communicate with instrument.
Surin
(3,445 Views)
