Instrument uptime
Hi!
Anyone know if there is a way to query the uptime/on-time for a Keithley instrument? Or some other way to get this information?
I'm using Keithley 2182A Nanovoltmeter and according to its specification it is only valid after 2.5h warm-up time.
Thanks in advance
/Peter
(4,936 Views)
Did you check the devices manual for a command in its (SCPI?) command language, which provides this information ? If there is no such command, you are probably out of luck.
As workaround i can think of a program which polls the instruments state by sending for example  IDN? queries and makes a time stamp when it is up.
(4,928 Views)
Yup I did, no command for that information.
Yeah a solution like that is possible!
(4,923 Views)
