em 09-21-2007 03:17 PM
em
09-24-2007
05:05 PM
- editado pela última vez em
02-24-2025
10:54 AM
por
Content Cleaner
em 09-26-2007 08:31 AM
em 09-26-2007 08:33 AM
em
09-26-2007
08:57 AM
02-24-2025
10:54 AM
por
Content Cleaner
The real key is that LabVIEW is not going to be able to everything on your PIC. Your PIC is going to have to have an application running on it which is capable of receiving commands over the serial port, and translating them to actions on the PIC. This application on your PIC would have to be written using a C (or other language) compiler for the PIC, or in PIC assembly using the tools that Microchip makes available.
I have done something similar in the past, where I created an application running on the PIC which was capable of receiving commands over the serial port. These commands were then translated into pulse-width modulated square waves on some of the PICs outputs. While this ultimately would allow me to use LabVIEW to control the PIC, I could not avoid developing the original application for the PIC to interpret the serial commands.
You may want to look into some of NI's low-cost USB interfaces, such as the NI USB-6008. This wil give you the ability to easy interface with analog and digital I/O, without the need to separately program a controller such as a PIC.
-Jason S.
em 09-26-2007 09:02 AM
