For this purpose you could use the
DEVCON utility from Microsoft.
You can use this tool to list all PCI-bus devices that are installed in your system in a command line (e. g. "devcon find pci\*"). If you are using LabVIEW you can call this command using the System Exec.vi. Then you can search the output string for the devices you are looking for.
Jochen Klier
National Instruments Germany
