IVI-com PowerMeter: Getting to Channel and Measurement interface and using FetchCwPower & FetchWaveform
I need a bit of help for the proper usage of the Channel and Measurement interface of IVI-COM driver. I have a sucessfully used the Active-X Automation Open, then the intiate methods via the class browser. Also know that there is communication with the device as some various properties can be set, but Im a bit stuck on the correct way to wireup and use the Measurements on Channel. In C# the syntax is myMeter.Channels.Items["CH1"].Measurements.FetchCwPower or FetchWaveform.
Pretty sure the Channels interface down Wiring down to the Channel, then passing the name in a constant, then to Measurements. But the Blue IsValid input and output wire connection are throwing me off, and causing labview to bomb. Any basic help with or example vi using IVI-COM and iviPwrMeter and the Channel Measurements would be appreciated!!
(4,962 Views)
Could you please send a screenshot of your code?  Also, what device are you trying to connect to?
-Devon
(4,939 Views)
Are you trying to use the class driver or the instrument specific driver? For the class driver, is your IVI-COM driver listed in MAX?
For an example of using the instrument specific driver, see https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PfCAI&l=en-US
(4,936 Views)
