03-27-2009 04:33 AM
Hello
want to connect a Tektronix TDS3014B from VBA (Excel), to read some Measures, Read/Write Configs, trigger the scope from a script ...
I've used the method found in a document found on the Vektrex Website (the only one i found):
First made the COM Object Available to the Project --> VBA Refences, IviScope Type Lib V3.0 & IviSessionFactory Type Lib 1.0 enabled
Code
Public Sub InitScope()
Dim SessionFactory As IviSessionFactory
Dim Oszi As IIviScope
Set SessionFactory = New IviSessionFactory 'Create a new Instance of the Object
Set Oszi = SessionFactory.CreateDriver("tkds30xx") 'Create an instance of the Driver, here comes an error
Oszi.Initialize ResourceName:="MyScope", idquery:=False, Reset:=True 'initialize the Driver and open connection
at the CreateDriver Method occurs an Error:
Runtime Error '-2147217149 (80041103)':
IIviSessionFactory: Software Module (tkds30xx) has no Prog ID
I've spend a lot of time to search IVI-C or IVI-Com-Drivers for this Tek Scope (or generic), that run from VBA / VB), but found only some diffuse hints to installations of Software like
SignalExpress Tektronix edition, but all of these software content nothing, that i can identify as an under VBA usable IVI-Driver.
Can you show me a way to become a real working Driver for Scopes in VBA ?
04-16-2009 04:55 AM
Hi Holger,
could you please tell us more about the website you found which describes the steps you used?
Unfortunately you can only use the Factory method with IVI-Com drivers. For the TKDS30xx we only have IVI-C drivers available. See also this thread that discusses a similar issue.
If you are able to use VB instead of VBA, you might want to take a look at this page, which requires you to install Measurement Studio.
Regards
