alled in PCI-bus IBM PC, which does not have GPIB interface. Which way would be easier for developing my own instrument driver: a new GPIB controller + interface or 2915 Kinetic Sys. PCI-bus in-slot interface? Can the latter interface be used with LabView?Victor,
I couldn't find an Instrument Driver for the 3932 crate controler. There is a driver for the 3988: http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/045f8392cc4d1b01862568ab005fbb49?OpenDocument
If you look at the driver it isn't too complex. Well ... actaully there are certain differences when using the 3988 GPIB controller that the driver takes care of that relate to correctly passing commands (FAN).
If the 3922 controller is similar then maybe you can use the 3988 driver and modify it to meet your needs. I'm not familar with the 2915 Kinetic system so I'm not sure what would be easier.
If you have a GPIB board, then you could try using the 3988 driver with your 3922 controller and see if you can modify the driver to get things to work.
I
've only used the 3988 and that was quite three years ago but it might be worth a try.
Best of luck,
Kamran - NI
