I can't find the NI Device Loader in the Service menu
I am trying to detect intruments in NI-MAX, one connected by USB-DAQ and one connected by USB-Serial. Despite the USB-DAQ appearing in the Device Manager, it is not in NI-MAX. And while I can see the USB-Serial COM port, I can't communicate with the instrument. The help resource suggested that I make sure that the NI mDNS Responder Service and NI Device Loader were running. I found NImDNSRS running in the Services menu, but the NI Device Loader was no were to be found. I have found advice on how to turn it on, but I don't know what I need to install so that it is available.
(12,793 Views)
Accepted by jbjz
It looks like you have not installed NI Device Drivers since The GPIB Enumerator service and a few others are missing too.  You can download the file from Here and Here
NOTE: the drivers finally got too large for one DVD and both are needed for a full install (part of why it ships on USB3.0 sticks now)
"Should be" isn't "Is" -Jay
(12,753 Views)
Thanks so much! I thought that I had installed the necessary instrument drivers, but apparently I had less than a quarter of them. I am now able to communicate with my instrument.
(12,700 Views)
I'm having the same problem.
I'm upgrading a bunch of systems from Dev Suite 2012 to 2014.  NI Device Loader is not showing up in Windows Services for 2 machines; a laptop running WIN XP Pro 2022 SP3 and a desktop running Win 7 Ultimate.  The other systems are running Win 7 Pro.  I've uninstalled MAX as suggested by http://digital.ni.com/public.nsf/allkb/D1F1D3FC80E4FFDF86256B410059DE31 and reinstalled the drivers.  No change.
Currently the laptop has no hardware connected to it so the missing devices and remote systems are from a previous configuration.  But it still bothers me that NI Device Loader doesn't exist.
I've enclosed a PPT document showing particulars about the problem desktop.
Any suggestions?
(11,985 Views)
Accepted by jbjz
Hi faustina,
Have you run Part 1 and Part 2 of the NI Device Drivers that Jeff posted? Also, since this is an older thread, it would be a good idea to repost your question in a new thread to get more responses from the community.
Eric H.
Eric H.
Senior Applications Engineer - Product Analytics
Emerson T&M (NI)
(11,939 Views)
Accepted by jbjz
no, I downloaded from the driver DVD that came with Dev Suite 2014 DS1:  LabVIEW 2014 DS2 plus driver DVD dated Aug 2014
(11,934 Views)
