I/O Trace ..
I'm trying to capture SCPI commands from LabVIEW 2012 VIs. The attached file is from I/O Trace 3.1. Some of the captures contain ".." and in some cases I am able to get the full string by going to "properties" and "buffer". But in the 2nd capture of this file even the buffer has "..". Is there a way to cature the entire SCPI string?
Thanks in advance.
Tim
(4,463 Views)
Hmm, it seems to be an issue with the size of the data buffer.
Here's a resource on increasing the size of the data buffer in I/O Trace:
http://digital.ni.com/public.nsf/allkb/EE93DB922C8146E586256904006B4F55?OpenDocument
(4,433 Views)
