annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
I CANN'T READ OSCOPE WAVEFORM FROM TDS210 WITH the GPIB APPLICATION EXAMPLES VI
Could you please let me know how to use this vi?
What arguments should be changed?
0 Compliments
Message 1 sur 4
3 914 Visites
Which example are you running?. You should run the getting started VIs. Notice that the getting started VIs use the Example VIs but provided the initialization steps (that the examples lack for generality).
To execute any of these VIs. Place it on the block diagram and open it. Fill the appropriate descritor with the instrument address (GPIB::3, for example) and execute.
Also, are you getting any error messages?.
DiegoF.
Message 2 sur 4
3 914 Visites
Hi DiegoF,
Thanks for the quick response.Yes, I changed both address parameters: in "Initialize.vi" and 'Getting Started1.vi" to "GPIB::5". I am still getting messages:
"Error- 1073807195 occured at Old VISA in TKTDS2xx Initialize.vi->Getting Started1.vi
Possible reasons:
VISA(Hex 0xBFFF00A5) The interface type is valid but the specified interface number is not configured."
I designed my own VI with NI Drivers. I had the same message.
Is it the matter what kind of GPIB card I am using?
I use Keithley KPCI-488 GPIB card for PCI Bus.
I designed programs for the TDS210 Oscope using commands and queries (from "Tektronix Programmer Manual") and Keithley GPIB card.
It worked,but it took more time to design them.
Why NI drive
r examples are not working for me?
Your response will be greatly appreciated.
Roman.D.
0 Compliments
Message 3 sur 4
3 914 Visites
The problem is that VISA does not support the GPIB hardware you are using. Basically, VISA needs an interface to communicate with the hardware.
This links shows the situation when using NI-VISA with HPIB boards (as an example):
http://digital.ni.com/public.nsf/websearch/E56D3D4866BE0A8A86256942006626F0?OpenDocument
You can contact Keithley support to see if they have support for this or have a workaround.
Another option is one that I found on a previous discussion forum. The problem is very similar, and this persons took the instrument driver and changed the VISA I/O calls to the GPIB calls for his hardware:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=5065000000080000000C310000&ECategor
y=LabVIEW.LabVIEW+General
Hope this helps.
DiegoF.
0 Compliments
Message 4 sur 4
3 914 Visites
