How to program SMC100
check tools/options and uncheck use locaied decimal point.
Our USA friends don't understand that it is a wrong default in LabVIEW to check this,,,,,
Message 11 of 18
(2,798 Views)
Thanks, I just had to reboot the computer and it worked ! 🙂
Message 12 of 18
(2,796 Views)
Hi, I am trying to programme SMC100 using LabVIEW. I have few codes which used to work but suddenly started showing error at initialization VI 'port initialize'. The error code is -1073807343. The inputs are com port, axis number and timeout. The controller works fine when operated through the GUI. Can someone suggest a possible way of fixing this error?. Thanks!
Message 13 of 18
(1,571 Views)
Hi
a long time ago I had the same error. The library was the problem.
I'll try to find my rewrite with VISA.
takes some time to find it, have to be at home for this.
Message 14 of 18
(1,567 Views)
Hi
I only found a library from 2005 from Newport.
The problem inside that library is that they are using "bytes at port" to determine the end of the communication but you can better update that with waiting in VISA for the termination character. Timing in windows and trying to ask a lot of small data parts only makes everything slower.
I don't know if you have the same lib but it is called
SMC100-Controller-Drivers
sorry for not finding my specialised version.
Message 15 of 18
(1,556 Views)
Thanks Albert. Geven,
Yes, I am using the library  SMC100-controller-Drivers. Sorry, but I am new to programming VISA  resources. The error is at the initialization VI. I have attached a screenshot of the VI for reference. After I input the COM port (checked in device manager and SMC100 GUI) and timeout (300ms) , the error is happening in the function 'Old VISA Open'. Could you please see if there is any possible mistakes I am doing?
Message 16 of 18
(1,547 Views)
I attached a version LabVIEW 2020
If this still does not work increase the timeout
You now should select the correct com port in the VISA resource.
If you don't have one check windows device manager and MAX from NI.
I only removed old stuff that is for over 10 years nonsens
Message 17 of 18
(1,536 Views)
Thanks a lot Albert.Geven!! The issue got resolved.
Message 18 of 18
(1,504 Views)
