Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to measure the frequency of a clock using counter in LabVIEW?
Ok. So is it ok to put the DMA outside the structure you provided, in another loop so that it would then read in the data from the structure you provided?
Message 11 of 13
(1,418 Views)
That really depends on your architecture.  I would put it inside that case structure.
Message 12 of 13
(1,414 Views)
Ok, Thanks a lot crossrulz.
Message 13 of 13
(1,411 Views)
