Hi feilong,
You should be able to create a local variable to do this easily. You can create a local variable of the baud rate by right clicking on the control/indicator selecting Create > Local Variable. You can then choose to read or write to the local variable by choosing the option when right-clicking on the local variable (Change to Read/Write). You can then drop this local variable down in your other loop, change to read, and you can then access the new baud rate.
Let us know if this works for you!
Rasheel
