How to create remote control via RS232 for microbalance
I want to do drivers via RS-232(serial line) for microbalance- communication with pc(remote control), i have manual  with serial interface but i don't know how to use it for programming in Labview. Can you help or show me some similar programs? My main problem is how to create start output - line composed of 15 words.
I attached pdf file , main VI and subVI...I know it's wrong subVI, instead of write buffer should be line composed of 15 words according to pdf but I don't know how can i make it.
Thank you for your potential help.
Message 1 of 9
(6,489 Views)
Yes, I didn't find the drivers for this microbalance(kern pej 603-m) there.... I need to create in labview them. Do you think it's too complicated?
Message 3 of 9
(6,461 Views)
Please look at the driver first. The protocol could be very similar.
No, it does not appear too complicated.
Message 4 of 9
(6,450 Views)
Ok, I am looking at it...i don't get it this part ....Can you explain me that, please? Why are numbers 2,1,6 there and what is abc character? Thank you, Dennis.
Message 5 of 9
(6,446 Views)
Can you attach an image of the block diagram? I'm posting from my phone and can't look at it.
Message 6 of 9
(6,433 Views)
Okay, up is subVI - calc weigh..i don't understand why is this so good if u can explain to me? Below it's used. I found "manual" -  remote controls for their device. I attached my pdf manual of remote control "remotecontrol" as well - according these parameters need to change it...They have written characters like t,w,s...But in my manual is just hexadecimal codes, how do I use it? Thank you.
Message 7 of 9
(6,427 Views)
It appears that there are differences between your model and the one with the existing driver. I haven't read in detail the manual for model (and it is incomplete) but if you right click on a string control/constant, you can set it to hex display. You can also use a U8 byte array and convert it to a string with the Byte Array to String function. There is a matching String to Byte Array that you would use after a read.
Message 8 of 9
(6,375 Views)
Accepted by safix
This is my weigh VI. I wrote [48-57] in decimal system. I found complete manual, on page number 85 is 0 - 9 (30 H – 39 H)=Data 0 to 9 (max. 6 characters in 6-digit format). Is it correct when i wrote [48-57] there? Can you modify my Weigh VI according my manual for show the output characteristics as shown in the manual for example: i would like to appear at the output signs(+-), weighted value with the units like "Continuous data output stable weighing values" of chapter 14.5 on page 88.  Thank you for helping out.
Message 9 of 9
(6,366 Views)
