How to control the testing instruments through GPIB
We are currently using Labview 5.0 to control the testing instruments (eg. HP DC power supply, spectrum analyzer, signal generator) through GPIB. Pls give us some simple guidelines to start and work with as we are just beginners.
(3,285 Views)
Hi Okj,
The first thing you should check is if there is an Instrument Driver available for your instruments. You can find more information about Instrument Drivers here:
Instrument Drivers (IVI, VISA) Support
There are a list of the top ten most useful links including links on just what Instrument Drivers are, where to download them from, and how to use IVI Drivers in LabVIEW.
Once you have this downloaded and installed, then there is an excellent LabVIEW example program that will get you started on communicating with your various instruments. In LabVIEW, click on Help -> Find Examples... Select the Browse tab, then navigate to Hardware Input and Output -> GPIB -> LabVIEW<->GPIB.v
i
Hope this gives you some good places to jumpstart your development. Good luck!
Kileen Cheng
(3,285 Views)
