03-24-2004 12:50 AM
03-24-2004
06:19 PM
- last edited on
06-23-2024
08:19 PM
by
Content Cleaner
Hi Okj,
The first thing you should check is if there is an Instrument Driver available for your instruments. You can find more information about Instrument Drivers here:
Instrument Drivers (IVI, VISA) Support
There are a list of the top ten most useful links including links on just what Instrument Drivers are, where to download them from, and how to use IVI Drivers in LabVIEW.
Once you have this downloaded and installed, then there is an excellent LabVIEW example program that will get you started on communicating with your various instruments. In LabVIEW, click on Help -> Find Examples... Select the Browse tab, then navigate to Hardware Input and Output -> GPIB -> LabVIEW<->GPIB.v
i.
Hope this gives you some good places to jumpstart your development. Good luck!
Kileen Cheng
Applications Engineer
