How to control a parallel port using VISA
I was asking about the device enabled box in max. It is not checked there.
Message 11 of 19
(3,458 Views)
yes. I changed that. but the error was the same. Is there any specific configuration for parallel port?
Message 12 of 19
(3,457 Views)
The only place that I know of is in device manager and in the bios. I don't have access to a win7 pc with a parallel port at this time so I can't check to see how it should appear.
Message 13 of 19
(3,452 Views)
Thanks dennis
Message 14 of 19
(3,448 Views)
Yes, you definitely want the "enable" box checked.
Check out these Forums:
(Scroll to bottom): port setting in BIOS needs to be set to SPP
http://forums.ni.com/t5/LabVIEW/Outport-vi-doesn-t-seem-to-change-parallel-port-register-values/m-p/...
=> Change the BIOS setting on your computer?
Parallel Port troubleshooting error codes
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Parallel-Port-Communication-resource-is-valid...
=> Check out the links from this forum
I am commenting here instead of the duplicate forum you posted here.
Joey S.
Senior Product Manager, Software
Message 15 of 19
(3,430 Views)
Thanks for the reply.
I changed ECP printer port to printer port in bios. I do not see SPP(standard parallel port) in my computer. I guess printer port and SPP are the same.
But i have the same problem. Are there any other solutions? I checked other two links also
Message 16 of 19
(3,417 Views)
Let's try these BIOS settings:
This KB refers to a different problem, but may help us in setting up the BIOS.
Parallel Port Does Not Appear in Measurement & Automation Explorer
http://digital.ni.com/public.nsf/allkb/31DC65938A666A9A86256F56005B2624?OpenDocument
It seems like connecting to the parallel port is much more difficult since Windows XP. For WinXP, we have LabVIEW examples that access the port directly (In Port and Out Port). One workaround would be using an XP machine.
Third Party
There is also is a third party driver developed for Vista that may also work on Windows 7:
It's discussed on this forum: http://www.vbforums.com/showthread.php?643913-RESOLVED-Writing-to-parallel-port-Windows-7-64-bit
Here is the actual Driver page:
http://www.highrez.co.uk/downloads/inpout32/default.htm
If we could get this driver to work, we could use a Call Library Function Node to call the driver in LabVIEW.
Joey S.
Message 17 of 19
(3,394 Views)
Thank you very much for your support. I am using a different computer with windows XP. it works fine
Message 18 of 19
(3,365 Views)
NI VISA controll PCI parallel port for Windows 10,
Windowns 10 can use VISA control PCI parallel port card?
Message 19 of 19
(1,495 Views)
