02-11-2007 04:40 PM
02-11-2007
05:41 PM
- last edited on
05-27-2025
08:25 AM
by
Content Cleaner
Where did you get the driver. NI doesn't have one for that model. If you got it from Thurlby-Thandar, the one they have is an IVI driver and you will need the IVI Compliance Package installed. It's on your drivers CD and you can check MAX to see whether it is installed. You can also get the latest at https://www.ni.com/en/support/downloads/drivers/download.ivi-compliance-package.html
02-11-2007 05:52 PM
02-11-2007 06:05 PM
02-12-2007 07:40 AM
Hi
Many Thanks for your swift replies. I did have VISA open when I got that message, but the initialise VI still does not work. I am typing "ASRL9::INSTR" into the resource name field (COM9) - and COM 9 works fine in VISA. Do I have to set up the instrument in IVI using logical names etc - which I have no experience of. Is there something that I could be missing
Graeme
02-12-2007 07:41 AM
02-12-2007 09:05 AM
I don't think you need to define the instrument in MAX unless you wanted to use the IVI class driver instead. Since you are using a serial connection, I'm wondering whether TT added serial support in their driver. I might be worthwhile sending them a query to see if they did.
One of the things I dislike about IVI drivers is that you need CVI to edit them. I have CVI but not on the pc I'm using right now. I'll try to find some time to get to that pc and look at the source code but I can't promise when I can do that. I'm assuming that the download page is http://www.ttinst.co.uk/downloads/drivers-download.htm. Exactly which driver are you using?
02-14-2007 06:01 PM
03-28-2007 09:24 AM - edited 03-28-2007 09:24 AM
Hi Graeme,
At the moment I am working on driver VI's for the TTi PL330DP.
The VI from TTi are old and don't work properly. There are also some errors in the commands which will be solved in the next print of the manual ![]()
Maybe you can use these VI's (when I am ready) or did you already solve your problem ?
Message Edited by K C on 03-28-2007 04:24 PM
04-01-2007 04:38 PM
