How to Transfer File from PC to Instrument via LAN by SCPI?
Dear All,
Any suggestions and the procedures?
Thank you very much!
(9,565 Views)
There is no generic procedure for doing so. You need to look at the instrument's documentation on how this is done. What instrument do you have? Have you looked in IDNET to see if an instrument driver already exists to get you started?
(9,557 Views)
Thanks for the reply.
I use the R&S FSV. And, I have read the document of this instrument, but in the document, there is no details to make it works. I have installed the NI VISA driver, I will use the NI VISA's commands and SCPI to control the instrument.So, I want to use commands again to transfer the calibration file to the instrument, to compensate the loss. Normally, we transfer the file from instrument to the local PC. But, this time I will transfer the file from PC to instrument. I'm confused. Please give me your hands. By the way, I use VS2008 to do this project.
Thanks again.
(9,469 Views)
If the instrument does not implement this functionality, it does not matter what language or orotocol you use. Check with R&S to see if there is something in the manual that you might have missed.
(9,464 Views)
Accepted by topic author zhou guixi
I find the method to do it.
I summary the produre below:
1. Open source file from host controller(fopen)
2. Get size of file(fseek)
3. Create command header(:MMEM:DATA)
4. Write file to the instrument(viWrite)
Thank you for the replies.
(9,460 Views)
Dear Zhou Guixi,
I want to do exactly the same thing you mentioned. Could you please explain the commands more?
(5,913 Views)
You might try looking at the manual on this page.  If you do not find what you want, try searching for SCPI and pick the desired topic.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(5,858 Views)
