10-13-2010 09:44 AM
My data acquisition application needs a set of two USB-5132 DAQ cards for simultaneous 4 channel data acquisition. I have around 20 of these DAQ cards for the field application purposes. By default I have configured the DAQ cards are Dev1 and Dev2 in my LabVIEW program and which is working fine. But when I remove the first two DAQ cards and connect different NI USB-5132 DAQ cards to the same PC, my program doesn’t acquire the data, as the system is taking these DAQ’s are Dev 3 and 4. This problem can be solved by manually resetting the “NI DAQmx Configuration” and changing the name of Dev 3 and 4 to Dev1 and Dev2 in the Automation Explorer >> Devices and Interfaces window. But I would like to make these changes programmatically through LabVIEW rather than changing the devices names manually in MAX. Does anyone know a method of allocating device names through Labview ( ver8.2) ? In short I want any DAQ device connected to the system to default to ‘Dev1’ followed by ‘Dev2’ (if second one is connected).
Thanks in advance,
Prashobh.
10-13-2010 12:23 PM
10-19-2010 08:55 AM
Dear Albert Geven,
Thanks for your reply. There is an option to "Reset the NI DAQmx Configuration" in the Measurement & Automation Explorer (Automation Explorer >> Tools >> NI-DAQmx Configuration >> Reset NI-DAQmx Configuration). If possible could you please send me the equivalent LabVIEW coding for resetting the NI-DAQmx Configuration.
Prashobhkumar.
10-19-2010 02:18 PM
I don't know how to call this function in MAX.
But as I said in my other post you can check which devices are available to LabVIEW and use an available device.
This is all I can show you
Short Name: DevNames
Property of DAQmx System
Indicates the names of all devices installed in the system.
The following table lists the characteristics of this property.
| Permissions | read only |
| Resettable | no |
| Settable while task is running | device-specific |
| Available in Run-Time Engine |
yes
