07-15-2005 03:19 AM
07-18-2005 04:56 AM
As long as you are using Measurement & Automation Explorer 3.1, to use the VISA Passport editor in MAX 3.1, select Tools » NI-VISA » VISA Options... Once the VISA Options screen appears, Select Passports in the tree view (My System » VISA Settings » Passports). Enable the NiVisaTulip.dll by placing a check mark in the box beside it and then click on the Save button. You will need to restart MAX for the setting to take effect. Once MAX is restarted, you will be able to access your third party GPIB boards and give them VISA aliases under My System » Devices and Interfaces » Miscellaneous VISA Resources.
If you are using a different version of MAX, please let me know
Katherine Robinson
National Instruments (UK)
07-19-2005 04:42 AM
07-19-2005 10:35 AM
Hi
Thanks. I turned the passport for tulip and I can see the GPIB instrument under devices. How can I give an alias to it.
Mal
07-20-2005 03:42 AM
