02-06-2009 05:28 PM
I am trying to make calls to my new NI GPIB-PCI board using an application that was developed using MSVC++ 1.52 on a Windows 98 OS. Using MAX I can see the board and communication to instruments on the GPIB works fine but when I try to use my application it keeps telling me that it can't find the device. I think the problem is that the application can't find the GPIB board. I decided to rebuild the application using the new API but then I realized that the new API is for 32 bit environments. MSVC++ 1.52 is a 16 bit environments. Any ideas how I can make this happen?
02-09-2009 08:45 AM
Hey Kuhlman,
Just for clarification I'd like to make sure we understand the issue. So your PCI-GPIB card is installed in a machine running Windows 98, you have a MSVC++ program that can't see the device. You developed a new program using a new API, but that new program is now a 32-bit application and won't run on the Windows 98 machine? Is that a correct overall description of the problem? Also, what new API did you use to the develop the new program?
02-09-2009 03:41 PM
I guess I need to state the problem more carefully,
I installed a new PCI-GPIB board in a Windows 98SE system which I hope to use to communicate with an Elgar power supply. I have also installed the accompaning NI-488.2 software (v2.2) to drive the GPIB board. Communication between the MAX included with this software and the power supply works fine. The problem is that I need to run a program that was written in MSVC++ 1.52 that does not seem to recognise the GPIB board. I can rebuild the test program in MSVC++ 1.52 but I do not want to spend time porting the code to a new MS platform (this will likely take months). The test program that I have uses an old GPIB board driver that was intended for use on Windows 3.1 with a GPIB-PCII/IIA interface board. That is, the test program is linked to the GPIB.lib that came with the original GPIB-PCII/IIA interface board. Is the problem that I am having due to the fact that the NI-488.2 software (v2.2) is 32-bit and the test program is 16-bit (I think MSVC++ 1.52 is a 16 bit based application)? Can I rebuild the test program providing a link to the GPIB-32.obj? I have already tried this and MSVC++ 1.52 got very upset I think because this is a 32-bit app and MSVC++ 1.52 is a 16-bit program.Is there another earlier driver package for the PCI-GPIB board that will work?
02-10-2009 09:31 AM
Hey Kuhlman,
Can you provide the model number or serial number off of the GPIB card you're wanting to use? This will help us determine whether or not there's a 16-bit driver available for that card that you could possible use. I'm also currently looking into what options you have for meshing the 16-bit app with the 32-bit driver.
02-10-2009 03:27 PM
Hey Kuhlman,
I found this KnowledgeBase article that addresses the exact thing you need. Try reviewing the information and see if this helps you determine how to fix your 16-bit and 32-bit incompatibility issue.
02-11-2009 05:55 PM
David,
Thanks for the info about the links. I have read most of those notes before and tried the appropriate suggestions (including turning on DOS support) without success.
My GPIB board serial number is 0x01378950.
I think the basic problem is that my application does not make calls to the gpib.dll. I have confirmed this by running NI Spy and no calls to the dll are made. To remedy this I would normaly link the dll to my source code in the build process. MSVC++ 1.52 does not seem to allow me to link to dlls.When I try to include the gpib-32.obj file included with NI-488.2 v2.2 I get an error. I think this error is because this is a 32 bit object file and MSVC++ 1.52 is a 16 bit application but I am not sure. I was hoping an earlier version of the NI-488.2 code might have a 16 bit object file that I can link to my application and rebuild.
Thanks for all your help.
Erich
02-12-2009 09:27 AM - edited 02-12-2009 09:29 AM
Erich,
The 16-bit version of the Language Interface is available for MSVC++ 1.52! Please refer to Language Interface: 16-bit Microsoft C/C++ to download the Language Interface files and a couple of sample programs. The web page also contains information about what you need to include in your application when compiling.
Hope this information helps!
gpibtester
02-12-2009 01:16 PM
gpibtester,
Your recommendation:
"The 16-bit version of the Language Interface is available for MSVC++ 1.52! Please refer to Language Interface: 16-bit Microsoft C/C++ to download the Language Interface files and a couple of sample programs. The web page also contains information about what you need to include in your application when compiling."
Is exactly what I am doing in the code but I still have no communication to the GPIB board.
I have tested the board response using MAX and the "Getting Started Wizard" and both checkout fine. Is there any chance that I need to change the resource settings?
This is getting very frustrating.
Erich
02-12-2009 01:42 PM
Erich,
I am sorry to hear that you are still having problems!
In an effort to figure out why you are able to see the Instrument in MAX (Measurement & Automation Explorer) but not with your code, I am asking you to do a favor for me.
I would like to see a case of where MAX recognizes your Instrument:
1. Setup NI Spy to start capturing (Performing a Good NI Spy Capture for Debugging/Troubleshooting)
2. In MAX, select the GPIB Interface. Next right-click on it. In the drop-down list, select Scan for Instruments.
3. Stop the NI Spy capture.
4. Save the file.
5. Attach the file to this thread.
Next, I would like you to send a code snippet that shows how you open a handle to a Board or Device along with the read/write calls.
With the above requested information, I think we will be able to figure out what's awry.
Thanks for bearing with us as we try to figure this out together!
gpibtester
02-12-2009 01:51 PM
gpibtester,
I will definitely do exactly what you asked. I have run the NI Spy in the past to see activity. Unfortunately I have to meet my tax guy right now so I won't be able to give you that info til tomorrow. I look forward to working with you to try to find a solution.
Thanks again,
Erich
