Hi
I've got Mindray's patient monitor and would like to get invasive blood pressure data from it's analog output.Is there any tool which can translate the signal so I can get pure data?
Thanbks
Do you know the exact nature of this analog output? NI sells a lot of different DAQ boards.
Thanks for that.
Actually I'm not looking for a tool that just traunsalte the signal,that I can do (I have got a the wave in the scope).
I'm looking for a blood pressure OEM that does the manipulation by itself and just output the systolic diastolic data.
Are you familar with such a tool?
I am not familiar with finished device that receives an analog blood pressure waveform and outputs the systolic/diastolic information. This would be relatively easy to build using a laptop and LabVIEW, however...
