Having problems installing the driver software
I am having problem installing the driver software for at-gpib/tnt board.Anytime I run the diagnostic test i always get the following error messages.I tried installing the software several times,still the same result.
ibdiag test-     Error reading NI-PNP.INI
ibtest test-      Unable to locate c;\Windows\GPIB.INI
GPIBinfo test- warning you do not have the GPIB.DLL driver installed.
I would appreciate if you could assist me in resolving this problem.
Engr Osayi .U
(3,063 Views)
answer here. Don't be so impatient to get an answer and post your question a second time.
(3,059 Views)
