Does anybody has an idea, how to read out the serial number of the GPIB board with CSharp .NET? Do I need some Measurement Explorer DLLs for this or what's the solution for this problem?
If you are using NI-488.2 version 1.7, you will need to call the GPIB-32.dll and use the IBDIAG call. Parse the returned data to produce the serial number and driver version.
Be advised, however, that this process will not work in 2.0.
I hope this helps!
Matthew C Applications Engineer National Instruments
Is there no chance to get the serial number in GPIB 2.1? We use the new drivers to develope with measurement studio for .NET in CSharp... I can view the serial number in MAX 3.0.2 (installed with NIDAQ 7.1). Is it possible to read the serial number over MAX?
Thank you for more informations...
Best regards Mike
"Matthew C" schrieb im Newsbeitrag news:506500000005000000035B0100-1075935269000@exchange.ni.com... > Hello Mike, > > Thank you for contacting National Instruments. > > If you are using NI-488.2 version 1.7, you will need to call the > GPIB-32.dll and use the IBDIAG call. Parse the returned data to > produce the serial number and driver version. > > Be advised, however, that this process will not work in 2.0. > > I hope this helps! > > Matthew C > Applications Engineer > National Instruments
Unfortunately, the IBDIAG call is not available in NI-488.2 version 2.1. This call is the only way to readily obtain the serial number programmatically. It may, however, be included in future versions.
Best Regards,
