 Neelesh
			Neelesh
			12-22-2008 04:23 AM
Dear Friends,
I would like to aquire a waveform from Agilent 54642A ocsilloscope into the LabView 7.1 programme via GPIB. Can anyone mention the GPIB read and write commands for the same oscilloscope???
Further, regarding the LabView programme, is it correct to place two GPIB write blocks followed by a single GPIB read block (All serially), along with an indicator, in order to check the waveform in LabView???
Kindly help me with your answers...
Looking forward to it...
Thanks a lot in Advance..
Neelesh
 Albert.Geven
			Albert.Geven
			12-22-2008 06:46 AM
01-04-2009 03:54 AM
Dear Friends,
I am hereby attaching a labview file for acquiring a waveform from Agilent 54642A oscilloscope to labview. But the program does not function correctly and therefore i am not getting the waveform in the labview. Can anyone modify the program and send me the correct one or send me some useful comments. The address and the command are already given in the program.
Further, can anyone tell me how to integrate a waveform in Matlab??I mean I have a waveform of arbitrary shape at the input and I want its integrated value at the output of Matlab. So I dont have the function like y=sin wt or cos wt.
Kindly reply me ASAP. It is urgent.
 Dennis_Knutson
			Dennis_Knutson
			01-04-2009 08:42 AM
 Albert.Geven
			Albert.Geven
			01-04-2009 11:45 AM
 shift
			shift
			06-24-2009 07:45 PM
Dear Friends,
I would like to know if you have a similar vi for Agilent 54825A ocsilloscope, for you know, it is an old instrument, and it does not support USB software supporting, and is difficult for read.
thanks.
SHift
 Dennis_Knutson
			Dennis_Knutson
			06-24-2009 10:06 PM
You should really start a new thread instead of posting to one about a different instrument.
All you have to do is go to the LabVIEW Tools menu and select Instrumentation>Find Instrument Drivers and enter the model number. You might also want to bookmark the Instrument Driver Network where you can start your search and find links on what a driver is and how to use one.
p.s. A driver for that instrument does exist, it's not really that, and compared to some instruments. not that hard to make work at all.
 shift
			shift
			06-25-2009 09:39 PM
Think you
I have found the software.
