GPIB one byte control
I have to control an old instrument with a serie of bytes, in binary format, one at a time.
Whatever I use, (VISA or GPIB 488), there are sent two bytes at a time, instead of one.
Why is that ? How do I prevent that ?
(4,382 Views)
Publish your vi and we have a look at it
greetings from the Netherlands
(4,369 Views)
(4,350 Views)
In the future, please post your VI rather than a screenshot. You can't debug a screenshot.
Your use of Format Into String is incorrect.  If you need to send out the bytes one at a time like that then you should be using the Type Cast function:
You should also use VISA unless you have a good reason to use the lower-level GPIB functions.
Message Edited by smercurio_fc on 03-24-2010 09:03 AM
(4,334 Views)
Or even better use the conversion function "byte array to string", assuming you have a u8 array.
And of course never use wait until multiple ms, because it is used in most NI examples in a wrong way.
Instead use wait ms or hardware timing when needed.
(4,309 Views)
The Byte Array to String won't work in this case because that will just give you a big long string of multiple bytes, and the user seems to need to send out one byte at a time, for whatever reason. You would have to snip out one character at time from the string inside the loop.
(4,308 Views)
Hi
You are right,
normally I use a subvi that transforms a byte into a character because we were used tp pascal it is called Char and accepts a byte as input and delivers a one character string at the output. Inside we use build array and array to string.
Nice test to see what is faster but I guess it will be the typecast.
(4,305 Views)
