在 02-12-2002 11:19 AM
在 10-18-2006 04:42 PM
在
10-19-2006
06:36 PM
- 上次修改時間
05-26-2025
05:18 PM
修改人
Content Cleaner
Hi Determined,
Is your AT-GPIB/TNT a plug and play (PnP) board or is it non-PnP?
Here is a link for installation instructions for a non-PnP board in Windows 2000.
Here is a link that describes one solution to an AT PnP device not appearing correctly in Windows 2000.
Please let me know if you have questions about this. I hope this helps!
在
10-19-2006
06:51 PM
- 上次修改時間
05-26-2025
05:18 PM
修改人
Content Cleaner
Hi rfengr_1,
The latest version of NI-488.2 (the driver for the PCI-GPIB) is 2.4 for Windows 2000/XP. Here is a link to the latest versions of the driver for different operating systems.
If upgrading the driver does not resolve this issue, please feel free to create a new forum thread so that we can work on this issue.
在 10-20-2006 08:59 AM
I have a similar problem however the card is installed in a ISA BUS thus : ( AT/GPIB-TNT)
the driver is listed in new programs however not MAX or HARDWARE MANAGER.
does anyone have a solution? I downloaded driver 1.7 and installed it in a Windows 2000 OS.
I did install version 2.4 of the NI488.2. Funny thing it installs version 3.1.1 of MAX.
If you've installed Labview 8.0, the MAX has upgraded to 4.0.0. I reinstalled LabView 8.0, which reinstalled MAX v4.0.0 and violia it works as it should.
I am surprised that NI does not provide an update for MAX or even if you select search for updates from within MAX 3.1.1.
Hi Determined,
Did you try my suggestion? What was the outcome? Do you have a plug-and-play (PnP) or a non-PnP AT-GPIB/TNT?
