06-09-2017 10:41 AM
Hello, I would like to have a feed back regarding an issue I am experiencing with the GPIB-USB-HS driver in Windows 10. Attached is the a snap of the VISA and NI-488.2 version I have installed. First time I installed the drivers it actually worked for windows 10, but after a windows update it did not worked any more. I have reinstalled the divers but still is not working. Can I have any feedback on how to proceed next.
06-12-2017 09:08 AM
Hello!
There are a few additional troubleshooting steps we can try.
Best,
Chris D. | Applications Engineer | National Instruments
12-27-2017 07:50 AM
Hi Chris,
I also have the same issue and tried your suggestion, but this didn't work. The HS device just isn't showing in the device manager, yet NIExplorer knows it is there. I actually feel like Windows10 doesn't allow the device to work. Perhaps this is a red herring, but, when I restart the pc, the controller goes into ready state, when w10 starts the device goes into active, then goes off. If I unplug and replug, the device never gets into ready.
I had the problem about a month ago, so updated to 17, but w10 forced another update on me and now I think it stopped working since then. Actually, I also noticed my pc cannot find USB instruments like TEK2024 USB devices.
Ryan
12-28-2017 03:44 PM
Depending on the set up of your windows system certain Firewalls or Anti-virus software can block communication over USB.
Another possible step is trying to turn these off, restart, and then try again.
12-30-2017 03:38 AM
Hi Dane,
Thanks for getting back to me on this. So I checked the firewall and restarted. This didn't resolve it. It is a windows 10 driver issue. My is version is 1709 build 16299.125. Windows 10 is being explicit the drivers are unavailable. I also did a repair on my installation, this didn't resolve the issue.
Ryan
01-03-2018 12:38 PM
Interesting,
Have you tried multiple different USB ports?
Possibly reducing the number of USB devices plugged into the computer?
Does the GPIB-USB-HS device work on a different computer?
If it is happening with multiple USB devices it could possibly be a problem with the Windows USB drivers.
01-04-2018 09:30 AM
I have two HS devices, neither are working on this pc... but both are seen, just no drivers supported... Both devices work on my office pc, both don't work on this pc (any port). This has the latest wX. It worked on here until the last update! I don't have any other USB devices on here when I'm trying to use the GPIBs.
To be honest it wouldn't surprise me if dell has done somethings in their control layers. So it is either going to be a dell update that resolves it or there is a genuine problem in the NI layer. I don't know enough about either so will work around the problem with serial for now.
Plug and play used to be fun! When it's plug and not play, it's rather infuriating...
01-06-2018 05:17 PM
I have enclosed a screenshot. My nose is near the grinder, people as asking me why I can't get this working. Dell just issued an update, that hasn't resolved it, so now it's NI turn. £1000 for each device is not cheap...
01-08-2018 04:11 PM
Hi All,
As a next step, I would like to see if this issue is local to the computer or not. Please attempt to use the device on another PC with a fresh install of NI 488.2 and VISA. I would be surprised if the issue is related to an OS update, it seems to be a driver issue. In the past I have seen this issue be fixed with an OS wipe (re-imaging). Although it is not the most glamorous answer, wiping all possible corruption may be the next step.
Best!
01-09-2018 02:51 AM
Hi Clint,
I just got your reply. I have the issue resolved.
So, you may be right that the issue isn't related to an update, it just so happens i had done an update, and then when i need to use it, i couldn't, the same day of the update.
My procedure to resolve this was to, uninstall the NI software, and re-install...however I had to do this twice, the first never resolved the issue. The second time I went through my registry and removed all references to National Instruments, IVI, visa etc. After this, it worked. Half a day beats an OS wipe, that would have been days of reinstalling so i wasn't doing that.
Thanks for your input.
Ryan
