11-10-2008 04:02 PM - edited 11-10-2008 04:04 PM
11-11-2008 05:10 PM
The only driver that we have available for RedHat 64 bit is for Red Hat Enterprise Linux WS 5. That driver can be found here: http://joule.ni.com/nidu/cds/view/p/id/1000/lang/en Please note that this driver is a beta and has not been tested to the same standards as other drivers.
11-12-2008 08:25 AM
Thanks Caleb,
I'm fairly new to Linux, so when I unzipped the file and tried running the install script I got this error:
"Kernel Source does not appear to be installed for the 2.6.9-55.ELsmp kernel. Installation of the Kernel source package for kernel 2.6.9-55.ELsmp is required to continue installation"
Is this just saying I need to upgrade my Redhat Linux to version 5.0, which is what the driver was designed for?
-Tony
11-12-2008 09:50 AM
Hi Tony,
Did you run the install script with a sudo command before it (just type sudo <command> )? I have heard of people who were successful in installing drivers on different versions of Linux, but I have not heard of this specific case being successful.
11-12-2008 10:03 AM
Hi Caleb,
Yes, I tried installing it with "sudo" and I got the same error. I think I will have to update my version of Linux
11-24-2008 01:39 PM
You, need to install the "kernel-devel" package. This driver may work on RHEL 4, but it is better to use RHEL 5.
Shawn Bohrer
01-22-2010 04:47 PM
Does anyone know if the Redhat Linux 64 bit platform has the same restriction as RHEL 32 bit does, where any kernel level USB driver > 2.6.25 HAS TO BE GPL compliant?
(i.e. not being able to use GPIB-USB-HS and the NI 488.2 driver in the latest Linux kernel releases )
thanks.
01-22-2010 08:02 PM
Well, RHEL 5 has a 2.6.18 kernel so NI-488.2 will still support the GPIB-USB-HS.
Shawn
