GPIB Session Open slow when DNS enabled
Using the NI VISA Drivers with C# code and perform the following:
try { mbSession = (MessageBasedSession)ResourceManager.GetLocalManager().Open(String.Format("GPIB0::{0}::INSTR", m_sGPIBAddress)); }
The operation completes but it takes 1 minutes + to find the device.  I have narrowed it down to the fact that the DNS addresses are configured.  If I disable the DNS it works properly however my system requires DNS to be enabled and 1 min + is unacceptable.  It appears it is searching the entire network for the device with the DNS enabled before finally finding it locally.  Is there some parameter I can set to force it to only look at local connections to find the device?
(3,090 Views)
(3,075 Views)
