‎03-28-2008 09:18 PM
‎04-02-2008 01:12 PM
‎04-02-2008 01:22 PM
Hello Bob,
From looking at the defined functions in the DDK, there is no option for an asynchronous read (only ni488_ibrd). This means that the ibrd call you make will block until either the time-out expires or it receives the data coming from the instrument. If you would like to poll for the ibrd, you can make the timeout really short using ibtmo. This will allow you to slowly poll to see if the data has come in from your device.
I hope this helps,
Steven T.
‎04-03-2008 12:07 PM
